Maytag Dryer
My maytag dryer seems to be over drying my clothes. The tech checked the heating element by turning on the unit during the air cycle and he said since the element did not heat duringthat air cycle that is was fine. He said it is thethermostat. When I looked at your part list it gave me two different swithes, #1 Hi-limit (303396, AP4036890), the #2 t/stat = multi-temp (306911, AP4037746). Which one should I get?
Thank you
The multi temp thermostat. The high limit is for a run a way heat. Tom www.applianceeducator.com/part.htm
thanks for your help
