Maytag dryer runs but wont shut off
i replaced the drum belt and 2 drum rollers and the tension wheel today the old one was so worn the dryer was full of dust and metal shavings from the bearing on the drum roller that i had to throughly clean the inside of the dryer housing and it took so long to do that i forgot how the wiring went on the front panel ie:door switch and the moisture senser and when i hooked it up it tripped the breaker immediatly so i rearranged the wires and now it runs quiet but it wont shut off when the dial comes to the shut off point on the dial what have i done to this poor dryer???and how do i fix it and where can i get a wiring diagram to download or a repair manual???
See that attachment for the wiring diagram.
I am assuming this is a USA model and not a Canadian model.
