Maytag dishwasher
control pad wont unlock by doing what the instructions say to do
Replacement parts for MAYTAG MDBTT70AWB Dishwasher - Undercounter | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/docs/wiring/TechSheets_11_17_09/Schematic%20-%20W10179503.pdf
[COLOR=“Blue”]control pad wont unlock by doing what the instructions say to do[/COLOR]
Not sure what you mean by unlock?
Try unplugging/ removing power from the unit for half an hour or so to see if it will reset.
Try running the diagnostics.
Perhaps the keypad (control panel) has an open key. Try the below cleaning if that does nothing check the keys with a meter.
The usual way to troubleshoot is check the keys with a meter. If all OK then it is probably the control board.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
