Dishwasher wont start,have replaced latch 6 months ago. Seems to be different problem this time.
Start with the obvious–and simplest place to check. Are you getting power to the dishwasher? Check the wiring connections under the machine to make sure none of them is loose. [COLOR=“Red”]It’s best to turn it off at the breaker before you start this check, to prevent injury or electrocution.[/COLOR]
If the power is there, and the connections are secure, the next place to check is for power to the door switch; If you get power to the switch, close the switch [COLOR=“red”](Remembering that 120VAC is lethal)[/COLOR] and check to see if it goes all the way to the control board.
Tell us what you find.
