Maytag dishwasher wont start
Maytag dishwasher touchpad lights up on all settings except normal but wont start on any lights stay on 30 sec then go off :mad:
Replacement parts for MAYTAG MDBTT60AWW | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/maytag_library/docs/16026393.pdf
Try to run the diagnostics.
Try the below cleaning
Unplug the unit
Open it up
Clean the edge connector.
If the above does nothing then check the keypad out using a meter.
If it checks out OK your control board probably needs replacing.
