Maytag dishwasher wont run
Some of the panel lights work but when you push start nothing happens. When you toggle between heavy, to normal, to light, to rinse only, they all light up except the normal. The high temp, lights up but not the snanitize, or the heated dry.
Did you ever find out what was wrong with your dishwasher? We are having the exact same problems and trying to figure out what is wrong. Thanks.
