Last night we couldn’t get the dishwasher to start. Most buttons on the control panel would not respond. For the past few weeks, the lights to indicate that the dishes were clean and sanitized failed to come on after the washing was complete. Tonight, we hit the start button and while no lights came on, the dishwasher did start. From what I’ve read, it seems that Maytags have had problems with control panels. Any ideas on how we should proceed?
Replacement parts for MAYTAG MDBH750AWB Dishwasher - Undercounter | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/maytag_library/docs/16026392.pdf
And a manual
http://www.servicematters.com/maytag_library/docs/16021814.pdf
Will probably be the keypad or the control board.
It is a biot of a crap shoot as to which one so check the keypad with a meter (see the tech sheet) if it checks out OK then I would go with the control board first.
You could try the following cleaning method but this is a long shot unless the connector has a lot of dirt in it.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
