Hello,
Maytag dishwasher model# PDB 1600 AWE
The door to the detergent dispenser doesn’t open.
Any suggestions, please ??
Thank you !!
Hello,
Thank you !!
Most likely the problem is a bad wax motor (#1 on the soap dispenser break down diagram).
Here are the break down diagrams for the Maytag dishwasher Model PDB1600AWE
Thank you Gene for the reply and the links.
I forwarded the info to my client and will post the resolution of the problem.
Thanks !!!
Gene,
Client gained access to the dispenser and found that the connecting wires are extremely short and one of them came off a connector. Client will reconnect after getting bettter access and it should work.
Thank you for your help. We all appreciate it !!!
