Maytag Dishwasher / Control Panel
Can no longer select different cycle lengths (other than “normal wash”). The lights on the control panel (except for the “normal wash” green light) also do not light up (“light wash”, “rinse only”, “start”, “clean”, “washing” and “drying”).
I switched the breaker off for a couple of minutes, but this did not fix the problem. Any suggestions? Thanks!
[quote=Carlos Peres;517872]Can no longer select different cycle lengths (other than “normal wash”). The lights on the control panel (except for the “normal wash” green light) also do not light up (“light wash”, “rinse only”, “start”, “clean”, “washing” and “drying”). [/quote][quote=Carlos Peres;517872]
I switched the breaker off for a couple of minutes, but this did not fix the problem. Any suggestions? Thanks![/quote]
Carlos,
You most likely have an issue with the control panel key pads,
AP4365229
[LEFT]If you have access to a multimeter, you can verify the button operation, using the tech sheet( attached to the backside of the kickplate assembly and the meter to verify you get a circuit when the button is pressed.
Heres some meter usage information:
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4810-how-check-continuity-ohmmeter.html
Good Luck,
[/LEFT]
