Brand:Maytag
**Model Number:**MVWB765FW4 Main Symptom: wash cycle messing up halfway through What happens & when: during wash cycle the wash water will stay filled in the washer and not drain until the washer is turned off. While this is happening, the timer will either keep counting down the minutes yet not draining the water and not going into the other phases during the wash cycle or it will add a lot more time to the cycle. Sometimes it will say three hours sometimes it will say seven hours to finish the cycle. Sometimes if I unplug it and let it set for 30 minutes or so it may work properly the next time by then again it also may not work properly the next time.
Parts or tests already tried: we have not tried anything aside from unplugging the washing machine
Photos / video link: I currently do not have any photos as sometimes it does not work properly and sometimes it does so I wouldn’t be able to get photos until it occurred again
It would be recommended to put the unit into service diagnostic mode to see if there are any error codes. Error codes will help with determining what may be wrong.
can you help me figure out what would be wrong with those codes. I’m not sure if they are separate codes E3 and F0 or if it’s F0E3 when I looked up that code in the manual you sent me it was the code put together F0E3 but I don’t know what that code means exactly and how to fix it
The F0 E3 error code indicates an overload issue. This is displayed when the main control detects a load size that exceeds the washers capacity or the basket cannot be turned. If the washer is not being overloaded, check for mechanical friction on the drive mechanism or basket. Items possibly between the inner and outer tub.
has soapy water, time keeps going down won’t drain or go to the rinse cycle. Will only drain if I turn it off then I changed it to a quick wash after un plugging it for 20 minutes and that time it stayed filled up but it was filled 3/4 of the way up and the time was changing from 1h 5minutes back up to an hour and 9 minutes then a few seconds after that changed again to an hour 19 minutes that is when I powered the machine off and then all the water drained out. I then did drain and spin so the clothes weren’t soaking wet
