This Maytag DW shows controls are “locked” but I cannot unlock the controls by pressing the "lock"buttons 3 seconds many times and more than 3 seconds.What can I do to make my controls unlock and make it work again?![]()
Replacement parts for MAYTAG MDB7600AWW Dishwasher - Undercounter | AppliancePartsPros.com
Here is the tech sheet and a manual
http://www.servicematters.com/maytag_library/docs/16023212.pdf
http://www.servicematters.com/maytag_library/docs/16021814.pdf
Not sure what you mean by pushing the "lock"buttons.
The manual says to use the heater dry button.
If this does not work try removing power (unplug or flip the breaker) from the unit for 20 minutes or so.
If this does nothing it could be that the Heated dry button is toast (shorted). Check it with a meter, see the tech sheet.
Thank you for your detailed reply with all the useful references.I will get the touchpad and try it out.Will let you know about the results. Shillion
Hello Denman,I got the touchpad control,and put it in,the dw is working just like new.Thank you very much for the detailed info so I could confirm the touchpad was the problem.You have been really helpful.I greatly ap[reciated your help!![]()
