Brand: maytag XL Model Number: MVWB835DW2 Main Symptom: out of balance fault code What happens & when: starts to wash and won’t spin out.
Error Code (if any): f7. E3 and f0 e2
Parts or tests already tried: I replaced suspension rods. I have been resetting by unplugging and then trying rinse and spin. It spun out with a cleaning cycle but won’t spin out with clothes in it. No noise from the transmission while it is running. I have leveled the basket. Have read that it may be a communication error or a lid lock, but that seems to be working fine.
Photos / video link: not available
Thanks for responding. I’m running an empty load now it’s agitating waiting to see what happens add ill let you know for sure. From yesterday I believe that it doesn’t try to spin. When it has clothes in it. But it spin out once with a light load. Didn’t make a lot of sense to me..
It did spin when it was empty when it went to stop spinning it started to make a grinding sound
Yes I can spin it freely and there’s no noise. I ran a rince and spin cycle empty it ran fine all the way through. Now running a 3/4 load on normal. Will watch and let you know what happens. Oh it does however when it started and was empty the tub moved sideways a little even at the base. Not like a spin though.
Just finished the load on normal and it ran fine. I do usually run it on deep water. Going to try that next.
