Hi
I have a Maytag 300 dishwasher that is stuck in “lock” mode. I Uunhooked the ribbon connector and cleaned it and reconnected. I then tried to enter “Field test mode” and the lock light blinks a few times and then stays on. Still won’t start. Could it be a bad touch panel or board?
I currently cannot find a tech sheet for your unit so cannot provide a method for checking the keypad.
Check behind the kick plate to see if the tech sheet is there. It should have the pinouts for the keypad. You then can check them with a meter and if they check out OK then the likely culprit is the control board.
Still a bit of a crap shoot but your odds are better.
If it is not there from the sounds of your symptoms the control board would be my first choice.
You may want to try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
