Quiet series 300 was operating fine but now won’t start. no lights on any control panel buttons. Any ideas??
Replacement parts for MAYTAG MDBS561AWB Dishwasher - Undercounter | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/docs/wiring/TechSheets_11_17_09/Schematic%20-%20W10111827.pdf
Here is a manual
http://www.servicematters.com/maytag_library/docs/16021814.pdf
First check that a breaker has not tripped
Next check that the unit is getting power, have seen where the house wiring connects to the units wiring goes bad re: the connection at/in the wire nuts.
Next remove the door’s inner panel and check the wires from the connection box up to the control board and door switches are OK
Next check that the door switches are both OK
