It started with the soap dispenser not opening, then that worked again. Then the auto wash cycle was starting at anywhere from 134 minutes to 158 minutes, then that went back to between 110 & 125. Then it went down to 1 minute left and stayed there and kept running, that went away. Then it stopped heating the water and is staying that way. All of the other problems were off and on. It fills o.k. and drains o.k. If I stop and open it during a cycle and then restart it the time may go up as much as 20 minutes.
Is this a control board problem and if so which one? Any suggestions would be greatly appreciated.
[quote=djtoo;834153]It started with the soap dispenser not opening, then that worked again. Then the auto wash cycle was starting at anywhere from 134 minutes to 158 minutes, then that went back to between 110 & 125. Then it went down to 1 minute left and stayed there and kept running, that went away. Then it stopped heating the water and is staying that way. All of the other problems were off and on. It fills o.k. and drains o.k. If I stop and open it during a cycle and then restart it the time may go up as much as 20 minutes.
Is this a control board problem and if so which one? Any suggestions would be greatly appreciated.[/quote]
Manufacturer’s module number for that unit is 00641945 Appliance Parts Pro number is AP4298189. Before you buy the control module verify that you actually have circulation. If water isn’t circulating it could cause a lot of these other problems because limit switches aren’t being tripped. After the water fills it should start to circulate right away. If you open the door and the spray arms aren’t coming to a stop as you open it they weren’t turning. You should also be able to hear the water circulating if you listen closely. If the motor is turning but the water isn’t circulating you most likely have an impeller failure.
