I Have A Wp Gold Qp Iii Dw & My Normal Light Is Flashing. It Did Quit Once And I Started A New Cycle And It Quit About 20 Min Into The Cycle And Is Flashing Normal Again. Any And All Help Will Be Welcomed!
Amy,
You most likely have a bad Normal wash keypad on the control panel.
(see below)
[LEFT]PROBLEM: WON’T RUN AND LED ABOVE KEY(S) IS FLASHING
RAPIDLY
Stuck key(s) or shorted circuit(s) in keypad.[FONT=Swiss721BT-BoldCondensedItalic][SIZE=1][FONT=Swiss721BT-BoldCondensedItalic][SIZE=1][FONT=Swiss721BT-RomanCondensed][SIZE=1][/LEFT]
Shorted circuits or connections on the control that read the keys.[SIZE=1][FONT=Swiss721BT-BoldCondensedItalic][FONT=Swiss721BT-RomanCondensed][SIZE=1]
Here’s how to reset the control board, when this occurs,
NOTE 1.
[LEFT]To start the Service[SIZE=1][FONT=Swiss721BT-BoldCondensedItalic][FONT=Swiss721BT-RomanCondensed][SIZE=1]
[LEFT]Diagnostics Cycle, press the following keys, in order, in less than 6
seconds, while in standby (off): Heated Dry, Normal, Heated Dry,[/LEFT]
Normal
** let the control board run the complete diagnosis cycle in order to reset **
And here’s the part number you’ll most likely need.
Good Luck,
[/SIZE][/FONT][/FONT][/SIZE][/SIZE][/FONT][/FONT][/SIZE][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT]
[/LEFT]
