O.k. was told by Gene to replace control panel for blinking lights. Finally got part put on and ran a normal wash / no heat dry cycle . Ran for 20-25 minutes or so got pass rinsing cycle and then stopped- lights blinking JUST LIKE BEFORE. Does anyone truly know what is going on cause I’m tired or ordering parts and waiting around for weeks to get them just to start all over again. Any thoughts would be appreciated.
What’s your model number?
And you mght want to double check all your connections, if one is loose it wll not run properly.
Nat
