Brand: LG Model Number: WM3997HWA Main Symptom: Not turning on What happens & when: outlet is in working order. Power cord is good. Power gets to the main board. No LED light on main board.
Error Code (if any): none
Parts or tests already tried: live multimeter test to power cord and power supply to main board. But no LED light on main board. Purchased and replaced main board. No LED light on new main board and still no power to the washer. Everything plugged in firmly and correctly. Wires and connectors look great.
Looking at your LG WM3997HWA main control board, I can see that your multimeter appears to be reading approximately 123 VAC. That’s a normal supply voltage.
However, there’s one important detail we still need to confirm: exactly which two connections you’re measuring.
If you’re measuring directly across the incoming Line and Neutral connections at the main board, that would strongly suggest the board is receiving the correct AC supply.
Since you’ve already replaced the main board and neither board shows an LED or powers up the washer, I wouldn’t replace another board yet.
Here’s what I’d check next
1. Confirm the 123 VAC measurement. Were your meter probes connected to two terminals on the main board, or was one probe touching the metal cabinet?
2. Check the main board’s power connections. With the washer unplugged, inspect the connectors for terminals that may have backed out or aren’t making good contact. I can see the connectors in your first picture, but I can’t verify their electrical contact from the photo.
3. Check the display/control panel harness. A problem with the display board or its wiring could prevent the washer from responding, even with a functioning main board.
4. Check for low-voltage output. If the board has a confirmed 120 VAC supply, the next diagnostic step is to check its low-voltage supply to the display board. We’ll need the connector identification or wiring diagram to identify the correct pins and expected voltage safely.
One question before we go further
In your second picture, where exactly are your red and black multimeter probes connected?
If you can tell me the wire colors or show a close-up of the probe locations, I can help you identify the next test points.
With two main boards showing the same symptoms, I want to rule out a wiring or power-supply issue before recommending another expensive part.
Thanks for clarifying! That helps narrow things down on your LG WM3997HWA washer/dryer combo.
With your black meter probe connected to the black wire at the black connector and your red probe connected to the blue wire at the yellow connector, you measured approximately 123 VAC.
That tells us there’s voltage between those two points, but we still need to confirm that they’re the correct Line and Neutral connections supplying the main control board.
Since you’ve already replaced the main control board and neither the original nor the replacement has an illuminated LED, I wouldn’t recommend purchasing another board just yet.
The next step is to verify the incoming power connections and determine whether the control board is receiving the voltage it needs to operate.
According to LG’s service manual, the no-power troubleshooting procedure includes checking for approximately 120 VAC across the two power filter connections before evaluating the main control board.
Encompass Research+1
Here’s what I’d recommend next:
Unplug the washer. Inspect the connections at the main board and the incoming power filter for loose terminals, damaged wires, or signs of overheating.
Check the power filter. If you’re comfortable performing live voltage tests, verify that approximately 120 VAC is present across the filter’s incoming Line and Neutral and its outgoing Line and Neutral. Otherwise, have a qualified technician perform this test.
Inspect the display harness. Make sure the connections between the main board and display board are secure, with no bent or pushed-back terminals.
One question: Can you send me a close-up picture of the black and yellow connectors where you placed your meter probes, showing the wire colors and their positions?
That will help me identify exactly what your 123-volt reading confirms and guide you to the next test without guessing at the connections.
Okay, I unplugged the washer and inspected the connections at the main board as well as the connections with the power filter and everything seems to be in order. Connectors are well seating and locked in. No loose terminals. No damaged wires. No signs of overheating. I checked the power filter with the multimeter and I do get at least 120 volts. I’m attaching a picture of that. I’m also attaching a close-up picture of my main board connectors as requested.
Thanks for the additional pictures and for checking all those connections! You’ve done a great job narrowing this down on your LG WM3997HWA.
Looking at your pictures, I can see that your meter is reading approximately 121.8 VAC at the power filter, which is right where we’d expect it to be. I also don’t see any obvious burned connections or damaged components on the main board.
Since you’ve already replaced the main control board and neither the original nor the replacement board shows an LED or powers up the washer, I’m hesitant to recommend replacing another part just yet.
1. Verify power leaving the noise filter.
Your 121.8-volt reading is encouraging, but we need to confirm that you’re measuring across the filter’s output terminals, not just the incoming power.
With the meter set to AC volts, measure across the two output conductors feeding the main control board. You should see approximately 120 VAC.
2. Confirm power directly at the main board.
Earlier, you measured approximately 123 VAC at the main board. If that measurement was taken directly across the incoming Line and Neutral connections, it suggests the board is receiving power.
However, if one probe was touching the cabinet or ground, we still need to verify the Line-to-Neutral measurement.
3. Check the control panel wiring.
With the washer unplugged, inspect the wiring harness running between the main control board and the front display/control panel. Make sure the connections are fully seated and that no terminals have pushed backward inside the connectors.
A problem with the display board or its wiring could explain why the control panel remains completely dark.
What I’m thinking
If we confirm that approximately 120 VAC is reaching the main board, but neither board produces its expected operating voltages, we need to investigate the board’s power supply circuit and whether an external component is pulling that supply down.
I wouldn’t condemn the display board based on the dark panel alone.
One important question before we go further:
In your third picture, where the meter reads 121.8 volts, are your probes touching the two wires coming out of the power filter toward the main board, or the two wires bringing power into the filter from the power cord?
That will help determine our next test without having you purchase another unnecessary part.
Safety reminder: These are live 120-volt measurements. Only perform them if you’re comfortable working around energized electrical components, using insulated probes and keeping your hands clear of exposed terminals. Otherwise, have a qualified technician perform the test.
