Brand: LG Top Loader Washing Machine Model Number: WT7300CV/03 Main Symptom: Code LE What happens & when: During Sensing Balance it will not allow it to go further,…it did before, but now will not do it. I can provide the sound that I’m talking about.
Error Code (if any): LE
Parts or tests already tried: Took Agitator off, nothing under sticking it.
The spin basket should not need to be lifted up to rotate it. This is usually an indicator that the spin basket is rubbing against the bottom of the tub due to the basket hub being damaged. It would be worth removing the spin basket from the washer to inspect it fully and identify if it has been damaged where it sits on the transmission shaft. Unfortunately, if it is damaged, it looks like the spin basket has been discontinued by the manufacturer from what I see in this link. AJQ73614213 Tub Assembly,Inner | Genuine Lg OEM In Stock
