Brand:
Model Number:
Main Symptom:dryer not heating
Error Code (if any):dhe
Brand:
Model Number:
The dHE error code on an LG washer-dryer combo or all-in-one unit means a dryer heating error. It signals that the system, the unit is not receiving proper feedback from the dryer or the fan/blower motor assembly. The causes for this can be tripped circuit breaker, thermostat, saftey fuses or stats, loose wiring or a failed element. This could also result from a fan/blower that is jammed or clogged. Lint build up reducing the air flow can also be an issue.
