I would start by checking the washplate. It is splined onto the transmission output shaft, and sometimes those splines can wear and allow the washplate to slip on the shaft.
Remove the cap and the bolt/nut holding the washplate in place, then pull the washplate off. Inspect both the internal splines in the washplate and the splines on the transmission shaft. Look for rounded, stripped, or damaged splines.
Test the transmission
If the splines look good, leave the washplate off and use a pair of pliers to carefully grip the transmission output shaft. Move the shaft back and forth like you were doing with the washplate.
Pay attention to where the noise is coming from. There will normally be a little movement in the drive system, but you shouldn’t have excessive looseness, grinding, popping, or rough spots coming from inside the transmission.
Next, unplug the washer and remove the rotor from underneath the machine. With the rotor removed, turn the transmission shaft by hand from the top again.
This is a useful isolation test because the rotor/stator is now disconnected from the transmission. If you can still reproduce the grinding, clicking, or knocking noise with the rotor removed, the transmission becomes the main suspect.
Check the rotor and stator
With the rotor removed, inspect the inside of the rotor carefully. Look for:
- Cracked or damaged magnets
- Loose magnets
- Scrape or rub marks
- Metal debris
- Signs that the rotor has been contacting the stator
Inspect the stator for cracked sections, loose mounting bolts, damaged windings, or obvious rub marks.
Also check the rotor mounting bolt and make sure the rotor isn’t loose on the transmission shaft.
Before reinstalling the rotor, rotate the transmission shaft by hand and listen again. Then reinstall the rotor and rotate it by hand.
If the noise is present with the rotor removed: I would suspect the transmission/gearcase.
If the transmission is quiet with the rotor removed but the noise returns after the rotor is installed: concentrate on the rotor/stator assembly, its mounting, or the rotor rubbing against the stator.
That should help isolate the noise before replacing either assembly.
