Brand:LG
Model Number:WT1201CV
Main Symptom:Water continuously fills even with power off.
What happens & when:Continuously fills with water
Brand:LG
If you’ve got water coming in even when the washer is unplugged then you’ve got a failed valve assembly 5221EA1008F that needs to be replaced
https://www.appliancepartspros.com/lg-valve-assembly-inlet-5221ea1008f-ap5244606.html
Are there any tutorial videos for replacing the valve assembly?
