LG Thinq water despenses slow after main shutoff
Brand: LG
Model Number: LRFVS3006S/02
Main Symptom: water dispenses slow
What happens & when: Water is dispensing at about 1/2 normal speed, 8 seconds for 4 oz. I have replaced the filter, tried to run water with no door filter (post 2022 model doesn’t require bypass), I have tested water line pressure prior to inlet valve which seems fine. This happened after the main shutoff was turned off for bathroom remodel. I have read to clean the inlet valve of any gunk that may have gone in after turning on water main, but this seems impossible with this type of valve. I have also read that this could be an issue with the water filter head. What would I do to check if it’s a water inlet valve problem or the filter head for the door filter?
Followup: if this may truly be the inlet valve, do I replace the whole assembly or just one part of it?
Usually, a slow water fill can cause ice cubes to be smaller than normal if the issue is before the diverter valve. If the ice cubes are normal-sized, it would be unlikely that the filter head would be an issue. With how the water system is designed in this unit, the water valve would be the most likely cause of failure. MJX65082204 Water Valve | Genuine Lg OEM In Stock
That was it. there was another powered valve connected when I went to install the inlet assembly. Guessing that’s for the craft ice in bottom freezer rather than the door water and ice water. But it worked.
