Ok, at that point the only thing between the dispenser and the valve is the water line. You might have air intrusion in that water line at the valve. The line itself isn’t serviceable except by replacing the door, but you can usually take the water line out of the valve connection and trim about a centimeter of it off with a razor knife so that it is flat and smooth. This will help ensure a good connection.
If the issue continues after that there is 1 more trick to try. Another manufacturer had a very similar issue, and if replacing the valve and trimming the line didn’t resolve things they suggested to install a check valve on the waterline in the door. If the waterline is 1/4" use WP2314271, if it is 5/16" use 8201815. The check valve can be placed anywhere in the water line between that valve and the dispenser, but tends to work best as close to the dispenser end of the line as possible. So, if you can, take the dispenser out and see if you have enough line to install it there.
That I’m not sure of, I think it should be the larger one that goes into the white fitting on the valve. Easiest way to check is to disconnect that water line and blow into it while holding your hand under the dispenser to feel for air
That could just be from the previously described leakage, but there is a water connection on the funnel assembly ADW73550403 that connects to the waterline through the door. You may want to check if that is loose or damaged.
That’s what I mean, if that connection on the funnel assembly isn’t fully seated you may be getting some spray in there which pools on the funnel assembly and then leaks down. I’d also check that the ice door doesn’t have condensation building up on it, that could mean the ice door isn’t sealing properly, you’d probably be seeing moisture build-up in the ice room compartment and clumping ice if the ice door was an issue though.
Water seems to be leaking down through the ice compartment at times then laying on the dispenser flap. I don’t see any way to view the funnel assembly. May need to replace the door. If that is what needs done what is the part number?
The full left fridge door is ADD76432301, BUT if you’ve got moisture in the ice room that may be your whole issue, and that could be just the ice door/cap duct assembly ABN76537402 not sealing or a problem with the ice room door gasket MDS62111103.
You can usually check the cap duct seal by shining a bright light up from the dispenser area and looking down through the the ice chute in the bottom of the ice room with the ice bucket removed, if you see light leakage that usually means a bad seal. You can also pour a small amount of water down that ice chute from the ice room side and look for water coming out in the dispenser area. If those are good check the ice room door gasket for damage or tearing.
Below is how you can get access to that cap duct if it needs to be removed:
That sounds like warm air intrusion into the ice room. Take a dollar bill or similar-sized piece of paper and close the ice room door with that paper sticking out. Slide that paper along between the ice door and the fridge door, you should have light resistance, if it has no resistance at a particular spot then the gasket isn’t making a proper seal there. Check that area on the ice room door and the fridge door for warping or anything like that.
Take a look at the vents for the ice room. There should be 2 vents on the cabinet wall and 2 on the side of the door that line up with each other. Check that those gaskets ADX73250609 aren’t pinched, torn, or anything like that.
I’m thinking that the warm air intrusion into the ice room is the cause of this whole thing, but after those gasket I’m not really sure what could be allowing that warm air in.
