Brand:LG
Model Number:Llmxs28626s
Main Symptom:leak in line coming from condenser
the line from compressor goes straight up in the foam is leaking way up in foam where does it go, should go to drier before the evaporator but is so far in to foam seems to curve around then go to inlet at drier, why is it run way in foam insulation am. I missing some thing should not go to evaporator until after drier and then to capillary, then to evaporator ? why is the liquid line run that way? Thank you James
