LG LRFVC2406D makes ice in door, but doesn't dump into bin
Brand:LG
**Model Number:**LRFVC2406D
Main Symptom:Door ice maker males ice, but doesn’t dump into bin
LG bottom freezer. Door ice maker freezes ice, but doesn’t dump it very often. I can manually force dump. I replaced ice maker last year, no change. Lowered freezer temp to -4, no change.
Craft ice maker in bottom freezer is working fine.
If the unit is not cycling the ice then this would likely be a faulty control board since the icemaker had already been replaced.
Thanks. Looks like there are three control boards listed for that frig, and one is no longer available. Would it be one of the other two? Is there a video showing the replacement of them?
The main control board would be the most likely issue and here is a link. Unfortunately, it is discontinued. EBR88309704 Main Pcb Power Control Board Assembly | Genuine Lg OEM In Stock
Thanks for the info. That’s unfortunate. Guess it’s time for a new fridge…
