LG LFX31925ST French door Refrigerator warm frig, warm freezer
Brand: LG
Model Number: LFX31925ST/00
Main Symptom: warm refrigerator @ 56 degrees, warm freezer @ 37 degrees
What happens & when: Fans were hitting on ice build up on evaporators. Thawed them out and reassemblied. Still have warm temps
Parts or tests already tried: Tested thermometer (thermister?) and got 0 ohms. Defrost heating elements tested in spec: 40 ohms & 80 ohms
Cleaned heavy ice off of both evaporators, tested compressor Amp draw, it is in spec. All fans functioning. I am going to replace the thermometer.
My question is should I replace both defrost system thermometers also, or just try the one main system thermometer (also heard it called thermister also)
If both evaporators have heavy frost build up on all of the evaporator then replace the defrost thermostats on both.
Am I replacing the wrong part then, if I replace the thermometer (thermister) to control the temperatures in both areas? PN: LG ACQ73244001
My thinking is that if I cleared the ice off the evaporators, but still did not get good Temps in two days and the thermometer tested 0 ohms, it is faulty and the clause of low Temps. But I’m a machinist, not repair person
So if there was no change in the temperature and the frost was only on the top section of the evaporator then this would be a sealed system issue and would recommend service.
Thank you for your time and patience with me!!
