Brand: LG
Model Number: DLGX7601WE
Main Symptom: Drum Light stays on, and unit will not operate
What happens & when: Drum light stays on any time the dryer is plugged in, and upon pressing the main switch, and afterwards, pressing the start switch, Dryer beeps twice, but does not turn on.
Error Code (if any): No error code, but the unit does flash a momentary “clean filter” message.
Parts or tests already tried: Wife called a repair man while I was out of town. He reportedly cleaned the door switch contacts. Unit ran normally for about two weeks. But he said we need a new main computer, which was puzzling to me, as the unit ran completely normally after he cleaned the switch contacts. So two problems…obviously related. Drum light stays on all of the time, and the unit won’t turn on. Unsure why the “Clean Filter” message momentarily shows upon initial power up. Both issues began at the same time. I already checked and thoroughly cleaned the entire vent assembly. Please help.
