Brand:LG Model Number: LFC25760TT Main Symptom: intermittent lights What happens & when: My frig and freezer lights work intermittently. When they don’t work, I quickly flick both door switches for a few seconds, and they come back on, but in a day or 2 they’ll go out again. I’ve replaced both frig switches Part Number 6600JB3007B
Yes if you are comfortable working with 120v you can check the out put from the door switches, check that 120v is getting to the bulb sockets. You can also check continuity thru the switches and thru the wiring harness
