LG DLE4870W Dryer will not stop spinning/shut off
Brand: LG
Model Number: DLE4870W
Main Symptom: will not shut off
What happens & when: Will only stop spinning when door is open. All Control panel functions work. There is heat. It completes the cycle. Clothes dry. Panel goes dark after cycle. No alert to tell you it’s complete.
Error Code (if any): No codes
That’s going to be an issue with the main control board EBR62707635.
https://www.appliancepartspros.com/lg-pcb-assembly-main-ebr62707635-ap5680237.html
Thank you for a quick response and for sending the link regarding the part needed!
