dryer quit after it had been on about 6minutes tried push to start switch and it didnt click could this be problem
Replacement parts for WHIRLPOOL LER7646EQ2 | AppliancePartsPros.com
Here is the wiring diagram
https://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203406692.pdf
Did the unit restart when you let it cool down or is it still dead?
I doubt it is the push to start switch.
More likely bad power or the thermal fuse.
[QUOTE=eula;99886]dryer quit after it had been on about 6minutes tried push to start switch and it didnt click could this be problem[/QUOTE]
First thing you want to do is flip the breaker off and on for the dryer a few times to see if it is tripped. If you have a meter check the power where the cord goes into the back of the dryer. The other 2 things it could be is the door switch or thermal fuse. It is usually the thermal fuse.![]()
