Leaky Water Inlet Valve
I have a leaking Water Inlet Valve (Part Number - 8268572) for a Kitchen Aid Dishwasher (Model Number - KUDM01TJBS0). I removed the valve, but I forgot to mark where the 2 wires connect. My question is can someone tell me which wire goes where on the valve. There is one brown wire and one brown/white stripe wire. Both wires have the identical connector. On the valve, one connector is marked 110/120V and the other is marked 60Hz.
I wanted to find this information out before ordering the part from your company.
Thank You,
Robert
Makes no difference
I received the part and installed it.
The dishwasher is now working.
Thanks!
