Leaky Dishwasher
Hello, I’ve been trying to figured out why my dishwasher is leaking around the motor area? It seems to be leaking for what I think is the pump assembly, the part that is conected to the motor? What do you recomend? Help.
I could not find any info on the given model number please check it.
Model Number Locator
If you can confirm that it is leaking from the pump at the motor seal then perhaps the seal can be changed. A small mirror and a flashlight come in handy when doing this.
Often it is a lot less hassle and work to just replace the pump/motor assembly.
Also then you know for sure that it will be OK when you are done.
