Leaking
Been having an issue with clothing still being very wet after cycle is complete, but no water in the tub. Last night we noticed water on the floor on the left side. Drain hoses and belts look fine with no obstructions that we can find and everything underneath looks dry but there did seem to be water in the drain pump (is that normal?). Running a small load now to see if we can make a more accurate determination of where the water is coming from. Any help is much appreciated - all three cars died within a week of each other so can’t do anything else major right now :frowning:
Operate it with the front panel off and see if you can tell where the leak is coming from. That is the way we usually diagnose the source of a leak.
If it is draining property the wet clothes may be the result of slow spin. Watch it with the front panel off to see if that is the case. If so, try changing out this part,
AP4009132
The video will show you how. It really helps to have a helper.
