I have water leaking out the bottom of the float assembly. Model #MDB6000AW series 10 (serial number 10235777sw). What part do I need to repair this unit ?
RMCain
Here are your parts.
Replacement parts for MAYTAG MDB6000AWW Dishwasher - Undercounter | AppliancePartsPros.com
You may not need any parts.
Remove the float from the unit.
Check that the tub tube for the float is not cracked.
Clean the float and tube, often crud builds up here and can be a path flow water to leak out.
