Leaks From The Bottom Right Corner. Is There A Seal Or Gasket There That May Need To Be Replced?
see if it leaks when you run it without anything in it, sometimes a bowl will deflect water to the corner causing it to leak. if it still leaks, it’s most likely the gasket, which, fortunately for you, is cheap and really easy to repair. the ribs on the gasket face away from you when installing.
hope this helps…
