Leaking around the impeller shaft to the pump housing
I have a leak around the impeller shaft where it connects to the pump housing. I just replaced the solenoid due to the unit not draining and the leak became evident. Is it possible to replace just the seal on the shaft? And how does the pump housing come off the shaft to do so?
Any clues? From the diagrams it looks like only the drain flap shaft has replaceable seals, but I can’t really tell.
I’m having this same issue. We’re you able to resolve this?
