Kuix305ess1 kitchenaide ice maker not making ice. Water flowing over evaporator but not freezing
Brand:
Model Number:kuix305ess1
Main Symptom:not making ice
What happens & when:water flowing over evaporator but not freezing
Test to see if there is 120 vac to the compressor start relay. If there is power and the compressor is running then this will be a sealed system issue that would need service. If there is power but the compressor is not starting then this will be a faulty start relay that would need to be replaced.
