[LEFT][COLOR=#000000]dishwasher will not start. Has power. have replaced the fuse before. panel lights up when turned on but in section where time left is displayed there are 2 dashes?? does this mean I need to replace fuse again of is there something wrong with panel? also has message to add rinse aid?? this shouldn’t cause it to not turn on??
I believe your model number should be KUDS01iJBL0.
I had to use upper and lower case because some idiot at Kitchenaide decided to use 1’s and L’s and i’s in the model numbers.
Just venting as I personally cannot think of any reason to do this other than causing confusion.
Try removing power from the unit for a couple minutes to see if it will reset.
I cannot say if the rinse dispenser will cause this problem but if you take a look at the dispenser (Item 8 in Section 2), you will see that they did away with the level sensing as it caused more problems than it was worth.
Click on it’s picture for more info and a Q&A section. KUDS01i.pdf (225.9 KB)
