Kitchenaide dishwasher issues
So I’ve had this unit for less than 2 weeks, ran fine since day one. Suddenly I have no response from the control panel. I checked all the obvious stuff, power is good, getting juice to junction box, all wires solid connection and grounded.
I don’t have ANY lights lit or blinking. It’s like I have no power to the unit at all.
Am I missing something? Unit is a KUDS30IXWH4
I will call a repairman on Monday if need be but just wanted to do my due diligence first.
Thanks for any responses in advance, Eric
Could not find info on a KUDS30IXWH4, the following is for a KUDS30IVWH3.
Replacement parts for WHIRLPOOL KUDS30IVWH3 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Probably the thermal fuse (item 6 in Section 2) is blown.
had same issue- replced thermal fuse and working fine now..now I have a leaking problem, but the thermal fuse was easy
