[QUOTE=Simon / APP Team;807393]Hi.
Check what is the voltage at the timer motor contacts.You should have around 115VAC.
If less - check the wire harness.
Simon.[/QUOTE]
I have 120.3 VAC at the timer motor pins. I put a video up of the timer operating briefly here:
KitchenAid washer timer - YouTube
note that the “wheel” connected to the motor is spinning. The “timing drum” to its right never budges.
(if it matters, the machine is agitating with the lid switch and water level switch both jumpered.)
