Kitchenaid refrigerator and freezer temps both periodically too cold
Brand:Kitchenaid
Model Number:KRFC300ESS01
Main Symptom: Refrigerator and freezer temps fluctuate quite a bit, 24F to 38F fridge and -18F to 0 F freezer. Both are colder than setpoints (38F and 0 F) majority of the time.
What happens & when: Symptoms cited are first thing in morning and through-out day when fridge and freezer doors are opened and closed. Food in fridge damaged by below freezing temps.
Error Code (if any): None
Parts or tests already tried: Replaced freezer thermistor; old unit checked fine. Replaced control board.
Using the tech sheet, place the unit into the service test mode (self-diagnostics), running the various tests to determine the faults.
TechSheet-W10787422-RevC.pdf (659.2 KB)
https://forum.appliancepartspros.com/
Here are the results. There were more Service Test codes listed on the tech sheet, but did not show on the display when toggling thru the sequence. Likewise, I noted some test codes on my display that were not on the tech sheet, so I do not know what they represent.
101 OFF
102 OFF
112 OFF
121 OFF
131 OFF
141 Fluctuate 9 or 10
142 -21
143 31
151 OP
152 CL
174 OFF
182 OFF (Confirmed that all LEDs work)
183 No display
191 OFF
201 OFF
202 OFF
203 ON ( I changed to OFF)
211 0.0
212 0.0
221 — ( I changed to dEF)
231 002
232 047
241 1
242 7
When I exited the Service Test mode, the display read -2 F (freezer) and 50 F fridge. These readings seemed OK since I had the fridge doors open while performing the diagnostic tests.
After running for about 30 minutes after the above testing, the display board showed 0 F freezer and 50 F fridge. My Taylor test gauges showed -10 F freezer and 37 F fridge. Any thoughts ? Thanks so much for your input.
…david
