KitchenAid KSRB25FHWH03 ice dispenser lever broken. How do I remove dispenser front cover w/o damage?
Brand: KitchenAid
Model Number:KSRB25FHWH03
Main Symptom: dispenser broken. Need to know how to remove front cover without damage.
What happens & when: The ice dispenser is broken, clear plastic ice funnel guide falls forward and locks dispenser lever ON when ice dispenser lever is pushed back; the lever and ice funnel guide need replacing. so I need to remove the front dispenser cover without cracking the plastic tabs so I can access the broken dispenser parts. I have removed the white plastic panels surrounding the top and bottom of the dispenser front cover, and that provides access to the front dispenser cover. But I don’t know where the locking tabs are located on the bottom and top of the panel, so I am hesitant to apply force possibly to the wrong area or worse yet, in the wrong direction. If someone knows how to properly remove this front cover, I would appreciate your advice and guidance. It’s 20 years old, and I understand it is out of production, so I can’t replace it if it’s damaged. My work around, for now, is to remove ice from the freezer’s ice bucket manually. BTW: the water dispenser works fine, only the ice dispenser is broken. Thank you for your help.
Error Code (if any):none
Parts or tests already tried:none
I would be especially careful removing the dispenser front cover. After 20 years, those plastic retaining tabs can become brittle, and forcing the cover in the wrong direction could crack it.
Since you’ve already removed the white trim pieces above and below the dispenser, you’ve made a good start.
Safest way to approach removing the cover
  1. Unplug the refrigerator before working around the dispenser switches and wiring.
  2. Use a flashlight to inspect the upper and lower edges of the exposed dispenser cover. Look for rectangular retaining tabs, grooves, or recessed screws.
  3. Check carefully for screws that may have been hidden behind the trim pieces you removed. Remove any screws before attempting to release the cover.
  4. Use a plastic trim-removal tool rather than a metal screwdriver whenever possible.
  5. If you locate a retaining tab, gently depress it while applying only slight outward pressure to the cover. Don’t pry against the middle of the panel.
  6. Once the cover is loose, support it carefully. There may be electrical connections attached to the dispenser switches or control assembly.
Important: I would not recommend pulling the bottom outward or lifting the cover upward until we confirm the retaining-tab arrangement for this particular model. Whirlpool and KitchenAid used several different dispenser mounting designs, and the removal directions aren’t interchangeable.
What I found in the parts diagrams
KitchenAid’s documentation for similar older side-by-side dispensers identifies separate components for the ice dispenser lever, ice guide, lever retainer, and front cover assembly. One diagram identifies the ice guide as part 2180224. However, I haven’t verified that part number or the exact cover-release method for KSRB25FHWH03.
AppliancePartsPros Forum
You can compare the assembly in this KitchenAid dispenser exploded parts diagram.
One thing that would help
Could you send me a picture of the dispenser with the upper and lower white trim pieces removed?
Ideally, take one straight-on picture and another showing the exposed bottom edge.
That will help me determine where the cover is retained and whether it uses clips or screws, so I can guide you through removing it without risking damage to an irreplaceable part.
For now, continuing to remove ice manually is a sensible workaround. I would avoid operating the ice dispenser until the guide and lever are repaired, since the lever is sticking in the ON position.
The bottom edge of the front ice dispenser panel shows two gaps along its edge as you can see in the pictures. My hope is that these gaps are significant keys to the type mount used behind this cover. The top and right edge of the dispenser panel show no clues to my eye in that they are continuous against the freezer wall.
Do these two gaps on the bottom edge help identify the panel mount type? I marked 4 contacts between the freezer door and front panel total. Two contacts of some sort that may be felt on the top edge of the panel, two contact of some sort that may be felt on the bottom edge. You may see their location on the freezer door marked in pencil. Still reasonable pressure on the bottom contact points do not release the panel. The same is true for the top connector points. Reasonable pressure on the top connector points do not release the dispenser panel.
Does this give you an idea of the proper way to remove the panel. Reasonable pressure from the bottom on the connector point marked in pencil does not release the panel, I am sorry to say. Thank you for your help.
did these pictures of the bottom edge of the ice dispenser panel help give a clue to how it is mounted on the freezer door? Thanks again for your help.
WE all put our heads together since I have never taken a dispenser apart on your particular model.
Yes using a small flat tip screwdriver or prybar, insert it into those 2 small grooves on the bottom of the faceplate. Gently pry it up and work your way up towards the top. It will hinge out from the bottom there are 2 2 clips 1 on each side that should disengage with gentle pulling pressure. I am going to attach a photo of the inside of the cover so u can see the attachment points. The only photo I could find was of a black one.
Thank you again for your help. This front panel was similar to the one you showed me but its behavior was not completely as expected, although it was close enough. The face frame around the ice dispenser cracked at the right lower screw joint, but what is important is I think it can be repaired, and made adequately strong again by adding an addional screw along the bottom of the faceframe near the clip point of the front panel.
What counts is it can be repaired and I could see both my ice door and ice funnel were damaged and needing replacement. Happily, both were available and I order them both plus two addition screws I’ll add to secure the front of the ice despenser frame which is screwed in already, but cracked it is cracked in a way it can be repaired.
Thanks again for your most excellent help and suggestions. The parts should arrive Thursday and with a little luck, we will be back in the ice dispenser business by Friday. Take care.
Always glad to be of assistance. Feel free to reach out anytime
