KitchenAid KRMF536RPS00 Water valve is double clicking every second and refrigerator is not cooling
Brand: KitchenAid
Model Number:KRMF536RPS00
Main Symptom: Water valve is double clicking every second; fan next to water valve not spinning; refrigerator is not cooling. Yes I already cleaned the condenser coils.
What happens & when: Center drawer user interface is inoperative (dead).
Error Code (if any): No error codes showing.
Parts or tests already tried: none
Photos / video link: none
With all the issues that are going on, this will most likely be a faulty control board that would need to be replaced.
Hi Ed,
And when you say control board I assume you are talking about the big main board on the back of the Fridge… Thanks for the tip.
Yes, that would be correct.
