KEBC208KSS0 Double Oven not heating up fully to set temperature. In Baking mode it is set to 450 and it heats to 350, and in Convection mode it is set to 450 and heats to 420. I’m not sure which part to replace: the Thermal Fuse or the Temperature sensor. My gut tells me the temperature sensor because if the thermal fuse failed open I would think I wouldn’t get any heat and I’m getting some.
Brand: Kitchenaid
Model Number: KEBC208KSS0
Main Symptom: Not Fully Heating Up
What happens & when: in baking set to 450 heats to 350 and convection mode set to 450 heats to 420
Error Code (if any): None
Parts or tests already tried: None
