Kitchenaid KBSD608ESS01 all freezer lights and one refrigerator light is dim
Brand: Kitchenaid
Model Number: KBSD608ESS001
Main Symptom: LED lights are dim
What happens & when: when I open the door, all the freezer lights and one refrigerator light is dim I replaced all the bulbs same issue
The LED’s on this unit run through the UI and you would need to get the UI for this.
https://www.appliancepartspros.com/whirlpool-ui-assy-disp-wpw10151236-ap6015796.html
Hi. Ok. Can you include a wiring diagram or instructions on how to replace. Thanks jerry
JS42PPDUDE01 Tech Sheet-W10910733-Rev A.pdf (622.1 KB)
Good morning. Thank you.
