Kitchenaid fridge kscs25mvms00 runs too frequently...temps in both compartment are perfect
Brand: Kitchenaid
Model Number: kscs25mvms00
Main Symptom:Runs too frequently
What happens & when: “cycles” on and off endlessly
It would be recommended to check and make sure that the thermistors are good. They would be the most likely cause for the refrigerator to cycle on and off frequently. Also check to make sure that there are no air leaks around the door.
Thanks for response…did not see any air leaking at seals. Did you mean posibly replace the Whirlpool WPW10225581 Defrost Thermostat OEM Part….located behind the cover in the freezer(watched the repair video)?
Here is a link for the thermistor.
https://www.appliancepartspros.com/whirlpool-thermistor-wp2188820-ap6006068.html
just finished the testing….got room temp readings of 3 ohms and the readings shifted with cold and hot exposure…did I need to be more specific with this test??
At room temperature the resistance should be 2.7K ohms of resistance. It sounds like it would be correct but if you could also let me know resistances at other temperatures would help.
Thanks for your help!! Here is where I am at…I ordered 2 new Thermistors(WP2188820) and installed them. The issue continues. Where do I go next?
Thanks again
Sounds like this issue will be caused by a control board if the boards are good.
DavidP_APP_Team
4h
There is a service bulletin out for this model. The control will have to be replaced with a service kit, W10823804 Electronic Control Board | Genuine Whirlpool OEM In Stock ……
