Had an electrical issue with the unit, shorted the fuse and circuit board, replaced both now will only run on extra clean and will not light up on normal cycle, does run thru the heavy cycle.
If this is the board you replaced, check to make sure the connections are secure; especially the ribbon connector between it and the touch pad.
Also be sure the electrical connections under the machine are secure; Make sure there is no loose ground or neutral.
