I have a kitchenaid dishwasher that stopped working mid-cycle. We checked the power sources, and they seem to be working. Could this be a blown fuse on the dishwasher? Or some other problem?
Replacement parts for WHIRLPOOL KUDP01ILBS5 Undercounter Dishwasher | AppliancePartsPros.com
Yes it could be the fuse (Item 6 in Section 2).
Remove it and check it with a meter. It should be 0 ohms.
If it is blown be sure to replace the wiring harness when you replace the fuse.
Yes, it could be something else (door switch etc.) but since power is OK I would start with the fuse.
I’ve replaced the fuse twice now. Each time the dishwasher worked for a while and then stopped working again mid-cycle. Is there something else I should try?
Since you have replaced the fuse and it’s harness twice there has to be something that is drawing too much current during a run.
My guess would be the motor the operative word here is guess.
Since it is intermittent it is not going to be easy to find.
Everything else seems OK so I am assuming that the filters etc. for the motor are all OK.
One thing I would check is the voltage to the unit, should be 120 volts. Low voltage can cause it to pull more current.
If the unit is not on a separate line try to figure out what else in on the line that may have come on during the run, dropping the voltage.
