Cycle switches, heavy & rinse only don’t light up. Normal, hi-temp, & energy saver dry do. When Normal is selected & start depressed nothing happens. When you hit cancel it clears panel, when cancel hit again by itself motor or pump starts up & nothing else, hit cancle again & it stops.
Powered off unit from the breaker, reset ribbon cable from control panel to control board still same symptoms. Any advice?? Control panel or Control Bd.???
Your Model Number seems to be short 3 digits (BL0 or something like that).
With those numbers I may be able to fi9nd a tech sheet which has the pin-outs for the keypad. This would then allow you to see if there is a line that is common to the keys that are not working.
Try the following:
Unplug the unit
Open it up
Clean the edge connector.
Sorry about that…the last 3 digits are BL4.
Replacement parts for WHIRLPOOL KUDI01ILBL4 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf
Go through the diagnostics to see if anything shows up as abnormal.
I would check out the keypad’s keys with a meter.
If it checks out OK then I would replace the Electronic Control Board.
Still a bit of a crap shoot but your odds are better since the control panel seems OK.
